I first heard about this part when someone was looking for replacement u-bolts for their SG2100. I don't have a DMS SG2100 but rather a Moteck one. I noticed that there are several manufacturers that make a 'SG2100' and I figured it was likely that some of the parts would interchange. This part is cheap so I figured it was worth a shot
50mm equals 1.968" or just shy of 2".
I didn't measure, but this tube seems to be a tad larger O.D. than my 1 1/2" Schedule 40 PVC stretched over the original 1 5/8" tube on the SG2100. This is a good thing!
Installation was a piece of cake. The only tool required was an allen wrench to take the single bolt that affixes the tube to the motor. I took the bolt loose and the nut just falls out of the other side of the tube where there is a hex shaped recess for it. Once the bolt is out, a gentle tug had the 1 5/8" tube off of the motor. The install was exactly the opposite. I put the 50mm tube on the motor and re-installed the bolt. The bolt was kind of an interference fit going in and out with both tubes but it wasn't too bad.
So you might be asking... Why spend the $$ on this when a couple dollars in PVC had me up and running?
With my two PVC sleeve setup, I could rotate the dish on the motor without a whole lot of effort. I think the PVC sleeve on PVC just made for a slippery union.
The good news is - With just the 2" Schedule 40 PVC sleeve, it feels VERY steady. The only dish movement I get now is the little bit of slop in the motor.
For anyone looking to put a dish with a 2 3/8" mount on a SG2100, this tube is definitely worth it.
This is yet another great product from DMS!
