Review: B1Sat
Sadoun
2,320
Columbus, OHIO
Sadoun offers the:
B1 SAT BANDSTACKED C-Band LNBF With Scalar
Pro Brand - Eagle Aspen
Sale $45.00 (Scalar ring included)
This LNBF is used for the C-band digital / analog satellite signal. It can be mounted on any Prime focus dish using the included scalar ring and mounting screws. LNB is designed for reception of signals in C-Band frequency range between 3.7 and 4.2 GHz. Ideally suited for reception of U.S. satellites.
  • Special for Digital C-Band Satellite Reception
  • Extended Frequency 3.7 GHz ~ 4.2 GHz
  • Bandstacked LNBF
  • L.O. Freq 5750
  • High Gain Output
  • Light Weight Design
  • 100% Waterproof
  • Adjustable Scalar Ring Included
Model Number B1SAT STACK
I/P Frequency
3.7-4.2 GHz
O/P Frequency
950-2050 MHz
LO Frequency
Lower Band 5.15 GHz, Upper Band 5.75 GHz
Output Connector
Type "F" Female Connector
LO Initial Accuracy ± 1MHz @ 25° C
Stability (-35°C to +52°C)
± 2.0 MHz
LO Phase Noise -60 dBc/Hz (@1kHz) -80 dBc/Hz (@10kHz) -90 dBc/Hz (@100kHz)
Noise Temperature
17 °K
Crosspol Isolation
20 dB
Conversion Gain
62 - 68 dB
Gain Flatness
± 0.5 dB /27 MHz
Image Rejection
40dB (min.)
Third Order Inter modulation -50 dBc (min.)
1 dB Compression Point
0 dBm
DC Voltage
10 – 24 VDC (supplied by receiver through coaxial cable)
Output Impedance 75 W F-Female
Output VSWR 2.5 : 1
With this LNBF you can use one coaxial cable to feed signal to one or more DVB receivers.
Write your reviews below.
Bought one last year and love it.. Stable, reliable down to -20 deg (cold as it got last winter)
Just remember to scan horizontal only, or you'll get dupes
Have had it set up for 3 months now and love it.
my "review" when I first set it up
Well I hooked it up and it worked.....sort of
Got dish locked on IA8 with the 621...90+ quality on Pansat 1500
Swapped out LNB...coax on bottom and the "box" (flat edge of LNB) almost level
moved to 91 and got V stuff fine....but not H. Set to "stacked" which is 5150/5750 and it works just fine...signals pretty much the same as the 621
When I do a blind scan what it does is it starts on the last 1/2 on H. What I mean is Pansats blind scan the IF frequency. So on a standard it scans 950-1600 IF. If its a universal or DBS it scans 950-2150. What this does is on H it scans 1550-2100 then on V it scans 950-1550. All the frequencies match up properly as if it was a regular LNB
So I hooked it up with a splitter (hi freq of course) to the Coolsat 8000 and the Quali-TV. Here is where I said it works...sort of
The Coolsat wont let me pick 5150/5750. I can select 5150 or add an entry as 5750. So it will work...but I need 2 satellite entries
The Q wont allow me to select 5750 at all. Gives me 5150 but no option for adding my own satellite LO....so all I can get is Vertical on there
But I can attest that it does get both V & H at the same time. Had the Q on a V channel and the 8000 on a H channel. Both playing just fine
so it does work. I'll probably hook it up to my main C-Band dish and run to a few boxes so they can get C-Band
so as long as your receiver can do 5150/5750 it will work fine
and pics with the setup
http://www.satelliteguys.us/c-band-satellite-discussion/147673-2-c-band-lnbs-6-foot-dish.html
Moved dish, now I can't get any signal
How deep a hole for 21' pole?
