I purchased an RCA DTC210 on the secondary market and it worked fine until a strong storm knocked out power. It is now working well, except that I had to reprogram it.
I run the locals through the box using my local basic cable package. To add confusion, I'm in one of those very few areas where there are two competing cable providers in my area. So, I put in my zip code and the sat channels are fine. Next came the cable set-up. There are two problems: 1) The cable channels picked up by the receiver are using the channel designations for the competing cable provider, despite my keying in the correct one. For example. If the local CBS on my provider is channel 5 and the other provider's is 7, my DTC210 must be set to 7 in order to get channel 5. Very weird. Problem 2) is that even after going into the edit channel list and clearing out the local stations for the previous owner's area, the remote will go to that empty channel. For example, the previous owner's Fox was channel 10 and my channel 10 is ABC. If I key in 10 on my remote I get the blank screen saying that the channel is unavailable. I then have to channel up to get mine. Again, I've done the reset and channel search and still get the previous owner's channels, then move them to the block side, but they still come up.
Anyone know how to reset or clear out this box so I can run a clean set-up?
Thanks.
Thanks.
