If you look at the first picture I posted you can see the area that clamps in the mount. Its on the feed horn right where it stops tapering, between the two ridges. It works pretty slick. To adjust the skew you just loosen the the clamp and rotate the horn. It has markings.
1.5" is close enough to 40mm that I would say you probably have the standard 40mm mount on that dish. I would probably bolt an Invacom or Dish FSS LNB to that feedhorn if I was replacing the current LNB.
Just to complicate the issue.....
Ultimately I'd like to have the 4 (or more) of the Primestar dishes that I have pointing at different birds and hooked up to one receiver through a switch. So I guess there would have to be a H/V switch on each LNB and the output would go to a 4 input switch of some sort.
If we just go with the 4 Primestar setup, that is 4 orbital slots, 2 polarities per slot. You can easily do this with two 4x4 or 4x8 (or 5xN) multiswitches if you want voltage switching from the receiver to "just work" with your LNBs.
Basically a 4x4 multiswitch has inputs for the H&V polarities of two LNBs. It uses voltage to select the polarity and 22Khz off/on to select the LNB/orbital slot.
13v/0Khz = slot 1 V
18v/0Khz = slot 1 H
13v/22Khz = slot 2 V
18v/22Khz = slot 2 H
A second 4x4 gets you:
13v/0Khz = slot 3 V
18v/0Khz = slot 3 H
13v/22Khz = slot 4 V
18v/22Khz = slot 4 H
[3rd & 4th can be added as well]
Then you just give each (of up to 4) receiver a 4x1 DiSEqC switch, with port 1 going to the first 4x4 and port 2 going to the second 4x4, etc.
So with normal switching for DiSEQc, 22Khz and polarity you end up with:
port 1 - 00Khz = slot 1 (H&V)
port 1 - 22Khz = slot 2 (H&V)
port 2 - 00Khz = slot 3 (H&V)
port 2 - 22Khz = slot 4 (H&V)
optional:
port 3 - 00Khz = slot 5 (H&V)
port 3 - 22Khz = slot 6 (H&V)
port 4 - 00Khz = slot 7 (H&V)
port 4 - 22Khz = slot 8 (H&V)
If you use 4x4 switches you can have 4 receivers connected to 8 orbital slots! All without using any fancy 8 port DiSEQc switches, or cascading DiSEQc switches. DiSEQc 1.0, 22Khz and voltage switching should work with almost any receiver.
