I recently had to down size from my BUD to a small k band system, due to relocation. I had been using a Cw 800s receiver for my bud. However, when I used it on my new system I could not get my old worn out remote to work.
I ordered a new universal one and still would not work. The selling agency replaced that one and it still did not work.
Therefore I gave up on another replacement.
I found info about how to determine if your remote is operating. If look thru a camera lens you can see if the light is flashing when you use the remote.
I used my cell phone camera and sure enough you can see the flash.
Then I really became frustrated, I was so frustrated I took my receiver apart and wiped all the front screens and everything else with a light coat of rubbing alcohol. I figured, what do I have to lose.
Plugged my receiver in, did a hard reboot and pointed my remote and gave it a shot.
What do you know it worked. Now I have two remotes that work. The older remote just needed the bulb to be re soldered to get it to work.
I guess the moral of the story is don't give up, try anything reasonable it may work.
