Over the years I have had excellent luck with those IDE to USB cable adapters. They seem to work 24/7 until the power supplies go bad. The power supplies do go bad with high failure rate compared to the adapter cables. But that hasn't been a real problem.
Lately, I have been using some of the larger SATA drives 1 Tb and up with a newer adapter that has both IDE and SATA connections.
It makes connection OK and I can initialize and format the drive but when I attempt to transfer some large HD video files like 150 Gb and higher to the drive it runs for about 20 minutes and then loses connection with the system. I have to disconnect and reconnect. Sometimes I have to reboot the computer and start all over again.
As an inconvenient work around, I have connected an 18" SATA cable to the Mother board and run it to outside the case with a power supply extension. This so far has been working.
I understand the USB adapter will be slower than a direct SATA but I'm usually transferring from a USB 2.0 ext cased hard drive anyway so I doubt speed would be improved.
The real question is why does the computer stop recognizing the USB to SATA cable adapter?
