Would anyone have any ideas on this issue?
To summarize, I am sending my antenna signal to a two-way splitter. From there, one antenna signal goes straight to one of my satellite receivers and has a very good OTA signal strength. The other antenna signal leads into a 4-way diplexer and from there the combined OTA and satellite signal travels to 3 more receivers. The OTA signal strength on these receivers is not near as good as the single receiver connected directly to the antenna. Does this indicate that I need to amplify the antenna signal? If so, would I do this before or after the 4-way diplexer? Would I need a separate amplifier for each of the signals running to the three receivers and should 10db be adequate?
Any help on this would be greatly appreciated...
Thanks,
Jeff
Thanks,
Jeff
