Recordings stop at 4:11 AM MST more than once.
KKlare
2,397
14
Los Alamos, NM
I have had several overnight recordings stop saying "user1" but I was asleep or otherwise off-line.
Last night I set up 2 722 recorders for Red Shoes on HDNet Movies at 4:00 - 1 min.
The reset was set for 3:33. Star Trek recorded, as usual, on one of them (Y) at 4:00.
Yet both stopped after 12 and 13 minutes. They have different remote addresses with the recorders in single mode. I doubled up just to check the recently replaced recorder (R) where I have had most of the stops because it is the one for most overnights. The ST recording was on the other and works every night including this night unless a duplicate. HDNet Movie shows (Y) T7 on 110 at 50-51 strength. And the same on R but it required a reboot just now to get out of the menus? BTW 119/110/129/61.5 on DPP44.
I just want it reliable.
The only other weird one is a timer for Nova on PBS OTA. All lists all shows even duplicates while New list all that have New in their listing even duplicates, which it shouldn't--a couple are bad listings with same episode having different first showings.
-Ken
Your receiver update your tv guide data automatically. Normally, at 3AM. Check in the menu, 8,4 to seee when your recorder is set to download guide data. You might need to change your download time to a time that you usually do not record. Maybe 6AM.
The guide download is done in the reset process--at 3:33 as set in this case. With plenty of time for the recording to proceed at 4:00. I have had other reboot times and still had this problem. Why did TVLand's Star Trek work covering the same half hour.
BTW although it says TV Guide on the guide, the data is from the Tribune Media Services as it says on the pages.
-Ken
Echostar Tweeners
Converting tv1 to UHF instead of IR
