I have never had a SAT equipment set-up before, so I have a few questions about my intentions to install a BUD SAT Dish at a property in the Caribbean islands (Turks & Caicos).
1) What size and type of dish would you recommend? (if space for a larger size dish is not an issue).
2) Is there a minimum size to not go "less than" that minimum size?
3) Is there any real REASONABLY SIGNIFICANT perceived benefit to going larger than the "not to go less than the minimum recommended" size?
4) Given a choice, if I have both DISH and DirecTV service here in the states, and wanted to bring one or both of my stateside boxes down with me when I travel, IN TERMS OF RECEPTION in TURKS and CAICOS, am I better off with bringing my DirecTV or my DISH box with me (legalities aside, as I did read a thread about that from an earlier conversation).
5) I did see that someone in an earlier thread was able to receive LIMITED reception of a HD signal on whatever dish they were using. Is there any possibility or sense of using one of the smaller DirecTV SLIMLINE dishes, with the 5 LNB's, in order to attempt to catch a HighDef DirecTV signal?
6) In terms of thinking about future EXPANSION and TECHNOLOGY ADVANCES when I order a Big Ugly Dish (BUD), is there anything I should be taking into consideration?
7) If I order a large enough BUD, is there ANY chance at all that I can capture a HD signal, and if YES, then what LNB should I order, and is a DirecTV or DISH LNB easy to attach to a BUD?
8) What other equipment might one suggest I be sure to purchase, with regard to installing a BUD for either DISH or DirecTV? I currently have the DirecTV Genie set-up in our office, and I was going to go back and forth with one of those boxes. Legalities aside, and talking about SAT RECEPTION ONLY, what SAT items need to be on my SHOPPING LIST before heading back down to the islands?
THANK YOU!!
NJTomH
THANK YOU!!
NJTomH
