I'm just getting started with satellite TV and have no equipment. I'm considering a Ku band system, initially for subscription service on the X4 satellite and would like to later expand with a moveable antenna and an additional receiver for FTA broadcasts. I was thinking about going with a 100 cm offset feed dish such as a Channel Master or somthing similar. We live in North Texas and often have high winds and I am concerned about using a DiSEqC/USALS/STAB type motor for various reasons, including durability in the presence of high winds, motor "play" for a Ku system, and positioning speed due to the limited current supplied through the coax to the motor. I have seen advertisements for positioning systems that are simiilar to those used on larger C band dishes in the UK (Satellite. Motorised satellite dishes heavy duty types from Andrews Channel Master. 90cm to 1.8m motorised dishes. Low prices) but have not yet seen these available from dealers in the US other than this one (H180: Moteck HH Mount Motor for 180cm (6ft) C-Band prime focus dishes). I understand that I would either need a receiver that was capable of interfacing to a standard C-band style motor, or an outboard positioner to convert DiSEqC to a 36 volt type motor. I was wondering if anyone has found a dealer in the US that carries a heavy-duty motor that will mount to a 100 cm offset dish, or if anyone could recommend a good system that is accurate for Ku band positioning and durable enough to withstand North Texas weather. Thanks for your help, Steve
