Reception Interference or technical problem?
Hotrod Lincoln
8
I have D* svc., with a 5LNB, H20, and older RCA SD rcvr., and Sharp Aquos 32" LCD. Several times a night, while viewing SD the color loses green and blue briefly, then comes back. Repeats a couple times then stops. From the HR20, I get "blocking" of the image, and then it restores. Climbing on my roof, it appears my neighbor's cedar tree tops, swaying from the wind, could possibly be occasionally blocking reception. Before I call for D* service, I'd like to be on the right course to the solution to make sure they head in the same direction. Your comments are appreciated.
I had a problem with an H20 receiver that was going goofy with all of the things you mentioned and then some. It ended up being the component outputs on the receiver. The way to check is to either try HDMI or the S-Video or the composite connections.( A different video output than the one you are having trouble with). If you are losing your signal from the trees, you should lose audio also.....do you?
Question for Memphis area customer
Altitude Sports channel going away for Plus?
