Unless it’s a power draw issue (which I guess is entirely posible especially with how weird slimlines can be), I don’t see any issues as DPP tech is interoperable with DPX (I’ll elaborate below).
Oh yeah, for sure. If I worked for Dish or any of their contractors (with the current Dish as it is, I probably wouldn’t) I would stick to what’s in the book more then anything as a CYA, but a little bit of “this will work in a pinch” knowledge never hurts.
And Duo’s/Wally, even though they would be fine with DPP. On the flip side you can channel stack them which is neat.
Now back to DPX. DPX is just a DPP signal with a third tuner stacked on top, and is what the Hopper1/2 requires for its three tuners. In the past a Node would perform the stacking of the third tuner with DPP setups, and now Hybrid LNBs have this functionality integrated from the get go. When you connect a DPP (dual tuner) receiver to a DPX line, or a DP (solo tuner) receiver to a DPP/DPX line, the receiver simply ignores the unnecessary tuners on the upper end of the frequency spectrum and uses what it needs on the lower end. This has been the case since the way early days of the DPP33/44 being capable of feeding a DP111 (heh remember that piece of garbage?). What I’m getting at in conclusion is that the underlying technology (DPX) is not only technically compatible, but quite literally by design made to be interoperable with DP/DPP as well. So:
Hybrid capable of DPX = capable of DPP/DP.
Again, and you are absolutely in the right here, if there was (for example) some oversight where VIP’s provide too-little/too-much power to a connected Hybrid LNB then that could be an issue, but the fact that the technology and underlying architecture is 100% compatible makes me think that that would be a hell of a screw up.
