Look at the check switch info. Power off (with the remote) and press the Info button. Or menu-6-1-3. The "Satellite" and "Device" lines are the interesting ones for us. That is lines G & H.
I don't have a DishNetwork receiver, just the Dish. I know it can see 119 and 110, and has a Diseqc switch built into it.
Well first off the splitter will not really work for what you want with a Dish 500, so you don't really need to worry about trying it.
Just to be clear - since I can explain things poorly - all I want to do is have NASA and the free DishNetwork radio stations available on both of my FTA TV Setups (separate rooms).
But... if you're hooking the splitter with "source" towards the Dish 500 and port 1 on Dish receiver, it should work like a couple or barrel connector.
I have no Dish Receiver, just the two previously mentioned FTA receivers, but the orientation you mentioned is how I was testing it. I assumed it would work just as you said (like a barrel connector), but it did not.
If you have a multi-meter test for a short between the center conductor and threads on the splitter. If you're hooking up just one device at a time and they are behaving like this, I would say there just about has to be a short. Confirm which ports you're connected to and that your patch cable is good.
I quickly tested, and no shorts. Also the splitter works if used to split a bud's c-band, so I don't think there's anything wrong with the splitter. Tested the cables, and used several different cable combinations.
I think so. Unless you're blocking power on one of those ports you will be backfeeding power to the opposite receiver. Even if you turn LNB power off.
Look up "BUD slave kit" on Sadoun or other sellers. Basically it is a power pass on *1* port splitter.
It's been working for a couple weeks this way. The arrows on the splitter show power going from the outputs to the input, but not from output to output, this is why I figured it was safe. Doesn't it seem like they should work for this configuration? Otherwise all multi-room setups would need a master-receiver right? Are you saying that only one receiver can provide power to a given LNB? This seems inconvenient since we might have selected a receiver to use a different LNB via a diseqc switch, and thus the first LNB would have no longer have power; useless to any other receivers right? I must be confused. I'll go re-read the FAQ thread about switches.
Have you tried using the loop out port on the VisionSat to feed the BUD?
This is a good question. I originally had it setup like that. I'm trying to remember exactly why I changed... Sometimes if the FTA receiver didn't see a signal, the 4DTV wouldn't see one either. So if I'm on a satellite, and I change the channel on the 4DTV so that the polarity changed, the FTA receiver would say "No Signal" and the 4DTV would see the new channel that I changed to, but sometimes it would then go away (I can't remember if this always happened, happened right away, or happened after a while). This might have just been with the Coolsat or the Traxis. I don't know if I tested it with the VisionSat.
