Receiver boot
re1354
9
I finally managed to get Telstar 5 signal. Here is the new problem that I have with my receiver. It boots once every few minutes. Does anybody know what the problem is?
Fortec 90cm, Captiveworks CS600 premium, 0.2 db LNB GT-sat.
I know nothing about Captive Works receivers, so I'm not aware of a specific issue for this receiver. But, it sounds like a TP (transponder) overload. Which is when the memory in most receivers can't handle the overload of saving to many TP's. If this is the case, then you can delete as many TP's as needed to free up space in the memory and it should be OK. Just a thought? Good Luck!
Al
Try re-loading the factory firmware ?
Wyr
Make sure you do not have a short in the coax cable . Does it re-boot if you remove the sat coax cable ?
Wyr
Free to Air newbee
ProgDVB
