RE: [VOOM] Two questions: OTA antenna and ESPN HD/ News
  • Thread starter Sean Butler
  • Start date
  • Replies 0
  • Views 921
S
Sean Butler
Guest
> I would put you OTA antenna as high as possible. I have my OTA antenna
> installed in my attic of my two story house and my sat dish is on my
> roof.
Which antenna do you have in the attic? I got the sensar ii. Most of my
channels are at 99 degrees, and PBS is at 353. 353 is unfortunately going
through several walls of house, including a stone one on the front. The
attic would eliminate some of that, or I could just put it on the roof line
so it is above the roof. I'm a bit wary of putting it directly into the
roof/shingles! 99 happens to be a clear shot with where it is now.
> As for the second question, did you receive the newest software 7.20?
> If not I would wait until you get it and see if this solves your
> problem. Also try a soft reboot, hold the power button in for about
> five seconds and release when you see the sat symbol go off ,
> or a hard
> reboot, which is to unplug the receiver for about five seconds and
> replug it in.
I've gotten the update and still have the problem. Voom said give it
another day and if it is still not working they will have someone come out.
My installer put in a diplexer so the STB is powering the OTA, and I
understand that can sometimes degrade both the OTA and sat signal. Not sure
if it could cause this LNB issue though.
Thanks,
Sean
------------------------ Yahoo! Groups Sponsor --------------------~-->
Make a clean sweep of pop-up ads. Yahoo! Companion Toolbar.
Now with Pop-Up Blocker. Get it for free!
http://us.click.yahoo.com/L5YrjA/eSIIAA/yQLSAA/EyMolB/TM
Yahoo! Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/VOOM/
<*> To unsubscribe from this group, send an email to:
VOOM-unsubscribe@yahoogroups.com
<*> Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
M
[VOOM] Here I Go Again...2nd try! :)
J
[VOOM] Caller ID with new updated software! Wilt can you help
Similar threads
