How far east/west or north/south did you move the dish to the pole, from the table?
Is there any chance you are now aiming through a tree, a power pole, or under part of your roof... or that of your neighbor?
You can double check your cable, and connections, and any grounding blocks you have in the path.
Did you add any new coax? Is it equal to the old coax?
Is the pole stable in the wind?
Does it sag from weight of the LNB, the dish, etc?
If you were using a motor, then rule #1 is:
Keep the pole plumb at all times!
If you are not using a motor, then off-plumb can be accommodated by other adjustments.
I was receiving WhiteSprings on a little dish, with a pole off vertical by a good
20º.
Just didn't matter.
And when all else fails by all means do check the skew!
