RCA DTC210 control Replaytv RTV3060 or visa versa
  • Thread starter Thread starter jdpeet
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
jdpeet
Looking for a "VCR code" for the RCA DTC210 to control a ReplayTV unit such as the RTV3060.
Otherwise, a way to make the off-air high definition channels on the DTC210 show up as the primary channel in the guide so ReplayTV can control the DTC210. For example, channel 2 is satellite non-HDTV, channel 2-1 is the high def. off-air channel. Replaytv can't select 2-1 so I always end up recording the low resolution channel.
I've tried blocking "2" in the DTC210 channel line-up hoping it would default to 2-1 but it just shows a black screen "blocked" channel 2. Thanks, Jd
call back from DirecTV
DirecTivo setup w/o TV!
