All,
First off, excuse me for the random stupid questions that I should already know. I *think* I know the answers, but I'd feel better with some confirmations .
Background: Currently we have a Slimline 3LNB dish with 1 HR34 Genie, 2 HR24s, and 1ancient HR21. Since I'm a dork and have enterprise/telco-grade equipment, I live unsupported and run Ethernet to everything. I even went totally unsupported and use split VLANs and disabled multicast routing to keep the playlists of the "younger kids" and "bigger kids" (aka adults) separate in MRV. However, we just got a 4k TV and I called to swap the HR34 out with a HR54 and add a C61K. They refuse to drop-ship them to me, so I'm going to put everything back in a supported config (no Ethernet, just Coax, using BSFs between the SWM multiswitch outside and the splitters inside to keep the playlists split) for the installer, and then probably switch it back again after he leaves .
So now that THAT is over with.. the stupid questions:
- Am I going to need a new dish/LNB from the installer, or will the current Slimline 3LNB work?
- I know the HR21 requires an external DECA when using coax networking. Does it need a BSF between the DECA and the receiver, or does the DECA itself have an internal BSF? I'm assuming it has a filter.
- I assume the HR54 is like the HR34, in that it will need a BSF in order to prevent it from acting like a CCK by bridging coax and Ethernet?
- On the HR24s, I currently use a BSF to 'force' them to use Ethernet. Is this really needed on the HR24s, or are they smart enough to not use coax networking when Ethernet is plugged in?
- The C61K I assume doesn't really have a tuner (since it's a client), and that it just uses networking to talk to the HR54. Since they sadly didn't include an Ethernet port on the C61K, is there any reason why I couldn't just piggy-back a CCK or DECA III on the back of the C61K to "give" it Ethernet? That way I can plug it in anywhere in the house where I have networking but not coax.
- And the craziest for last: I know that the DECA III can be powered via USB or EPS10 power adapter. I read somewhere that the USB seems to only work when connected to a receiver. Is that true? If it is, does anybody have an EPS10 handy that they can read the 'INPUT' line on them to see if they are 120VAC only or if they accept 120VAC-240VAC? I can't find a decent close-up picture anywhere of a EPS10 to tell. My main server cabinet where my existing CCK is is mainly ran off a 240VAC UPS. Because the power adapter on the CCK is 120VAC-only, I had it and the GenieGo/Nomad on a smaller 120VAC UPS. Since the GenieGo/Nomad seems to be basically a doorstop now, I'd like to get rid of the 120VAC UPs if possible. I'm hoping either the EPS10 can take 240V, or if the DECA III will run off of any USB power, I can use an IEC C7 cable into an iPad charger to get USB power off of 240V!
Thanks all for the help and for dealing with the stupid!
