Has anyone tried using the old Dtv world direct dish (dtv66e 36x24) or the Starchoice dish (75E 35x26) for use with Dtv ls3/ls5 swim Genie setup? These dishes are similar in size and bigger than the Dtv Slimline. It looks like the mounts are the same as the Slimline and if they are all that would be needed is one of the reflectors that can be swap out with the Slimline reflector. If the sl3 swim does not work I am sure the older 3lnb with swim setup would. I have a Genie HR44/200 with one Mini C41-100 with the Extra package and live in southern Idaho. I estimate a 35 foot cable run from sl3 to the Genie with one 2 way Dtv splitter.
Also has anyone tied using an outside antenna setup with a Genie swim system? I was thinking of dropping my locals and using an outside antenna using the Am21 OTF dual receiver, a Sonora AD14 amp diplexer along with a Sonora sdswmd2 diplexer designed to work with the Dtv(Dish) swim system to merge locals in and out of the same cable line without affecting swim signals.
