radio on pansat 2700A
havenx
211
On my pansat I get a radio channel when I do a scan but it is not showing up in my channel list or anything... what do I need to do?
On your remote, there should be a button with "TV/RAD" written on it. On my remote, it's located just under the #7 button. Press this button and it should show you if you've captured any radio on the particular satellite you're on. Note you will have to press it again to go back to TV. Hope this helps.
Also, while you're on Radio, you can use the Sat button. And with it you can bring up a list of all stations you've captured on any of the satellites. The same as you can use it with TV.
Al
some radio stations (likeon G10) utilize the 2nd audio on a channel
as an example, WBIF (1st one in the 11799 mux on G10) has a radio station on Language 2 :)
But voomvoom is right about the other...hit the radio button. On the Pansat its on the top right (at least it is on the 1500)
Ecua TV is a gonner.
signal meter and skew?
