Radio missing from E* 119?
flyinggreg
32
Columbus,OH
I scanned E* 119.0 and had radio one day and then it was gone about a week later. I am confused - are they gone or maybe I am hitting wrong sat. I thought I was hitting 119.0 but when I rescanned it, I found a "Congrats! You have a SuperDish pointed at 121.0" any clues? I tried repos east/west and can't seem to hit any other E* nearby. Oh yeah BTW - Fortec Classic NA, 80CM, Invacom QPH-031
you must be on 121...your LO frequency is wrong. Should be 11250 for 119
make sure you are on the "C" side of your LNB or Diseqc switch
That's all setup. I try moving the dish to the east and still - no joy.
You should know 119 when you hit it.It's pretty strong as are all the echostar stats.I always scan them in and use as a reference point while looking for other sats.You should not need to move the dish too far from where you are at 121.
true. Some of the odd transponders are spot beams so you probably wont get them
12224 V is the 1st one and is a spot beam. As John said, use 12238 H to aim
119w is VERY close to 121w... just a nudge east. In fact, 119w is SO strong that you should be able to find it by just "pulling" the dish a bit on the left side (while standing behind the dish).
The audio channels on E*119 have been shuffling. Over the past two weeks "FMONE" has disappeared from the line-up, or perhaps it's been renamed. Either way the EPG is showing different channels. ENVONE is still there and it was adjacent to FMONE.
These are the two most popular monaural Muzak channels.
DIsh has moved the channels around so it might be a better option to delete the channels and rescan the satellite. I just did that the other day
as an example, the PPV Preview channels moved from 110 to 119 and a few audio channels moved around :)
updating softward for pansat 3500s
Cnn Usa
