R15 Duel recording
Denman007
117
5
What is the trick to get this thing to record 2 channels at once? I added a 2nd feed this evening.
I had 2 feeds that I know are good - because I had them connected 1 at a time and had a picture with both of them.
So I hooked them to Sat 1 and Sat 2. Set the guide to record channel 6 and channel 29 at 8pm. Tells me I have a recording conflict.
Would the reset button fix it? What am I doing wrong? I don't use the DVR to watch TV, I use my H20 for that.
Thanks.
If you only had one cable connected and then changed to 2, you have to reset the R15 in order to get it to recognize both connections.
Thank you. I thought that might be the problem, but it was about to record one of my programs and 1 was better than none.
I will reset it this evening.
switching from E* to D* - need 2 HD receivers
Annoying Message !!!!
