First of all, I live in Puerto Rico, we need 2 dishes one for 119 and another for 110. Now to my questions.
I want to use DishPro LNBs. I imagine I will need Dish-Pro SINGLE LNBs for each dish, right? I guess the duals wont work because both will try to get 119/110 but I don't know.
Is this like a square to D-style adapter? I ask because one of the dishes uses square tubing and I could use something like this to install the LNB without much problems. The other dish just has a clamp that grabs the neck of the LNB (does that config has a name?). I know that I can remove the cover of the DishPro LNB and use it but is it ok?
Now if I can install the LNBs, how would I do the cabling? My guess is split both singles and then use 2 DP21PRO switches (or one DP34) to merge the 119/110 signal into one cable. That way I would get 119/110 on each cable and feed it to my 522. Is that right?
