Sonyajon,
Since you are using the AZBox, remember to look into the thread regarding "How to North Americanize Your Sat List". This can be a tedious task, but it isn't anything that requires a huge amount of technical prowess. It is simply dull, repititious and time consuming.
If you are setting up both Ku and C band systems to run on the one AZBox, you will want to utilize the strategy outlined in the instructions for "How to N.A. Your List". To cut to the chase here, if there are two satellites at the same orbital location and one is Ku and one is C-band, you can develope them in your AZBox list using the same orbital degree slot, but distinguish between the two by naming them uniquely (like Ice presented concerning AMC 21 @ 125.0°W for Ku and G14 @ 125.0°W for C-band). It is acceptable for these two sats to share the same orbital location, you just have to separate them in the list by giving each sat their own specific name. Then you may set the LNBF parameters to define one sat as Ku band and one sat as C band and this will require two LNBFs.
If you are using a motor, when you switch between the two sats, the motor will not move, but the electronics will switch between one LNBF and the other.
If you don't like keeping track of the official satellite names, all you need to do is name the sats by degree and band... i.e. "125.0°W Ku" and "125.0°W C".
Hope this is making sense for you.
RADAR
