I plan to use the Echo Plus to be the main Echo in our Den. My Hopper3 is not located in the Den. It is upstairs in an office. I plan to configure Alexa to the Hopper3 with the Echo Plus upstairs and then move the Echo Plus to the Den. I will use an Echo Dot in an upstairs Bedroom and the other Echo Dot in my smaller downstairs office where Joeys are located. So, will that work? Will I have to ID each Joey with its location, e.g., so when I send commands do I need to address as Den Joey or Bedroom Joey, etc. I just want get all my ducks in a row before starting the process.Open the Alexa App on your phone, go to Skills, search for Dish and follow the prompts
This is something you're going to have to experiment with. I only used my Echo Dot to setup the Hopper so I could do it for my customers, then I put it on a shelf. I'm using Google instead of Alexa at my house. The best I can say is try it and see what happens - and let us knowI plan to use the Echo Plus to be the main Echo in our Den. My Hopper3 is not located in the Den. It is upstairs in an office. I plan to configure Alexa to the Hopper3 with the Echo Plus upstairs and then move the Echo Plus to the Den. I will use an Echo Dot in an upstairs Bedroom and the other Echo Dot in my smaller downstairs office where Joeys are located. So, will that work? Will I have to ID each Joey with its location, e.g., so when I send commands do I need to address as Den Joey or Bedroom Joey, etc. I just want get all my ducks in a row before starting the process.
Hey, aabom! Only our Hopper receiver will provide you with the Alexa App through the DISH Menu. When pairing your Echo device, you would perform these steps at the Hopper, and these features are able to be used by the Joeys. To help, you can rename the receivers so the Echo device knows which room to perform the function on. To rename a receiver, please press the SYSTEM INFO button on the front panel to open the Diagnostics, then arrow down to Whole Home. Towards the right of that screen you will be given the option to "Change Name."I plan to use the Echo Plus to be the main Echo in our Den. My Hopper3 is not located in the Den. It is upstairs in an office. I plan to configure Alexa to the Hopper3 with the Echo Plus upstairs and then move the Echo Plus to the Den. I will use an Echo Dot in an upstairs Bedroom and the other Echo Dot in my smaller downstairs office where Joeys are located. So, will that work? Will I have to ID each Joey with its location, e.g., so when I send commands do I need to address as Den Joey or Bedroom Joey, etc. I just want get all my ducks in a row before starting the process.
