I bought and installed one of the new SL2 Bullet dual output LNBF's on a system and I'm experiencing a lower quality signal causing pixelation on some TP's.
The issue is with the 97.ow. The dish is a GEOsat pro 90 cm equipped with the dual LNBF bracket, it's aimed at the 97 and 101. The problem is that the quality has dropped about 8% compared to the standard single bullet LNBF.
Example, with the single output LNBF I get 43% on TP 12115 and 35% with the new dual output model, I put the single back and it goes up to 43% again.
I spent over 2 hours trying to fine tune this baby with no luck, it doesn't compare to the single model.
My question for Satellite AV is; have you had other consumer's experience the same issue? Is there a known issue with these new models or could it be defective? Please advise...
Your help is greatly appreciated.
