Question about install...
Pyrophoric
71
Question about satellite installation...
Ok, I am a newb when it comes to satellite tv and am getting it installed for the first time this week.
Atm, all I know is that I am getting a DVR 522 from Dish Network and the installer is from a local satellite install company.
So, what should I look for or be aware of when the guy comes? I mean, should be aware of what type/model dish I am getting, if its new, or even if the DVR is outta the box new?
I used to work for the local cable company till I quit so I do know a good bit about cable in general but almost nothing about satellite.
Basically, what should I expect from the installer when he comes out?
Thx a ton ahead of time for any info and thx to those who have already helped me with my past questions :)
Well, my first recommendation is to search for "install horror story" or "bad install" or the like.
Second, a 522 requries 2 feed cables (or DPP gear). This means you'll be getting a DP Twin on a D500 (unless you're in a SuperDish-for-locals area).
Third, beings you don't own the 522, refurb or new is not relevant - same as cable STBs.
First, what is a superdish? :)
Second, since it needs two feed cables I would assume that they wont just be using the cable line already there?
Third, I have read the horror stories and it has made me really worried about what to expect from Dish and the local installer.
I see many stories but not to many fixes or solutions...
So that is why I wanted to start this thread :)
Thx a ton for your help :)
Edit : I think I found something on what a superdish is .. is it for areas that can get local channels? If so I guess that is what I will be getting since I can get locals.
You will only need a Superdish if your locals are not on the 110/119 birds. In San Diego, my locals are at 119, therefore I only need the Dish500. You could also use a Superdish if you subscribe to American and International channels.
Pyro - without knowing where you are, we can't ay whether you'd be getting a SuperDish (119+110 plus either 105 or 121) or just a Dish500 (119+110) or Dish500 with a "wing" Dish300 for either 61.5 or 148.
Big V was partially right - different areas have different setups for locals.
Four 510's or two 522's ?
Dish Network with Sony HDTV?
