Question about grounding outdoor antenna
shugo77
633
Heart of Dixie
I just installed a cm3018 antenna outside my house on my roof. I am concerned about it being properly grounded to protected against lightning, especially since I live in southern Alabama where we can have some pretty strong lightning storms during the summer months. :eek:
I have been able to find some resources on the net, but none have had any simple, easy to undertstand instructions for the do it youselfer, like myself. :confused:
Does anyone have any advice or know of any grounding kits I can purchase, Thanks in advance. :)
http://www.channelmaster.com/pdf/3014_20manual.pdf
From this it says:
The mast and transmission line should be grounded for lightning protection. Run a #8 (or larger), aluminum or copper wire from a bolt on the mast or its base, down to a 8' ground rod. Keep the line at a respectable distance
from your transmission wire to prevent signal interference. A coaxial grounding block (Channel Master Model3274), should be connected to the antenna transmission wire at the point where it enters the house.
OTA HD Locals
OTA antenna in attic??
