Quality
alfonsosorino
12
Moncton NB Canada
Hi,
I am trying my best to get all the channels from the IE5 but the problem is that the quality after all the trials and the setting is very low for some TP like 11874 H on 22000 and am not sure of the cause. is it something related to the LNB which is a Universal one. your suggestions please.
some transponders are low due to bandwidth purchased.
As an example, the transponder that has Daystar, TBN, Church Channel etc is a 70 quality but some of the other ones (mostly the Arabic ones) are at a 35
So What you is your suggestion, I mean does changing the LNB may help and what is my other alternative. Some say that changing from Universal to single LNB may help and some say that Universal invacom is the solution so what do you think from your experience point of view. apart from that even most of TP on G10R are with low quality.
Most Universal LNB's I have tried over the years alway produced lower signal quality, that was until I got the Invacom. Universal and 0.3db its got the lot. I would recommend a standard LNBF or an Invacom.
Big Thankyou To All That Helped
Anyone Using The Fortec Lifetime Ultra
