As a public service to all of you who invest heavily in quad shield RG6 coax for your installations -a little inside beta from an installer's point of view.
You are probably wasting your money if you have your connections made by D*.
You need to realize that the D* technician is only equipped with PPC compression connectors designed to fit RG6 D* branded 60% braid only.
When we roll on a job pre-wired with quad - our connectors do not fit!!!
So what do we do - one of two things, the most common is to use the cable prep tool to etch away at the shielding until our connectors will slide on or we burn/melt the insulation with a lighter until the connector will slide on.
In either case - we usually end up seriously negating the benefit of using quad by completely mutilating the thing at each connector point.
Thought you should know.
P.S. - and please...no RG11 either - it's a pain trimming it down with a pocket knife to fit the D* issued connectors too!
