By experimentation. The satellites at both 110 and 119 are closed enough that, with a 6 foot dish, you will likely get both satellite positions. The dish adjustments are likely the same as for a regular Dish500. The skew adjustment made by rotating the Dish500 is pobably not a viable option on a 6 foot dish. Instead, you'd have to tilt or skew the lnb mounting angle of the line drawn between the center of the two translucent covers of the twin lnb. A protractor type clinometer would be a definite plus in this matter. The angle would be the same as the angle of skew on the Dish500, but you'd rotate the lnb instead.
