finally, after a long aggrevating affair with customer service and thier field rep/installers inability to deliver i had enough, ill get my HD fix by some other means.
Make sure you do your homework next time.
You can do all the homework you want; however what do you do if Dish decides to raise your DVR advantage plan $10 a month?
I am 5 year out of contract sub, whom spends upwards to $100 a month, and am not to thrilled when I hear about a 10% rate increase in these hard financial times.
The increase better be worth it, in new programing, otherwise I will have to strongly consider my options once my nhlci subscription expires in april, whether I am addicted to my "Duo HD Dvr" or not.
I don't blame you. I am still without TV after a month, because customer service can't get their sh*t together.finally, after a long aggrevating affair with customer service and thier field rep/installers inability to deliver i had enough, ill get my HD fix by some other means.
(Whadda prick) You can do all the homework you like, but that doesn't help when they repeatedly screw up your account.Make sure you do your homework next time.
Yep and Dish is doing a disservice to thier coustomers.. whats funny is that charlie claims that he's the cheaper of the two services and trys to negotate and play hard ball with providers to keep your prices down. guess what charlie, with that 10 dollar increase you just became more expensive than Directv who... hasnt dropped as many channels as you have! OMG!
what options do you have available in your area? I assume directv, perhaps cable, fios/uverse?
You should be able to get the locals and both of the RSNs (plus a few more) that you mentioned in HD with D*. Not sure what TWC lineup is there, so I cant offer advice on them. What DVR do they use?Well, I can choose between directv or time warner. TWC has been adding HD as of late, but are still behind E*, however they do have my rsn (MSG) in HD; they do offer YES network (in HD too) and all the locals in HD (E* doesn't have the ABC or PBS). If they keep adding national hd like they have in the NY City area, then I might just have to kiss my dvr goodbye.
Back at ya. He did not know what he should be getting, therefore did not refuse the install.(Whadda prick) You can do all the homework you like, but that doesn't help when they repeatedly screw up your account.
I have been tossing and turning on switching from Dish to Direct for awhile now, but am scared to because of the negative DVR reviews I am constantly reading about.
Its not as bad as some would lead you to believe. They did have some widespread issues at launch, most of which have been eliminated. Pretty nice receivers these days, although by the accounts of most that have both D* and E* not QUITE as good as the ViP series.I have been tossing and turning on switching from Dish to Direct for awhile now, but am scared to because of the negative DVR reviews I am constantly reading about.
I dont think they are saying that now because of problems, because as far as I know there are no widespread problems with the HR these days (no moreso than with the ViP anyway). I think most of them are going off of features that they like, and a slight difference in speed (which is something that I havent noticed with my HR-20). IMO, having used and being a sub of both (although I dont have the ViP) the HR is as good as the E* offereing for what I use it for. I have no need for a sd feed to the second tv, and I dont care for PIP. Others do like those features though, and I can understand that. That said, both have features that the other doesnt. It all comes down to what you want in a box, and to a larger extent, what you are familiar with. The learning curve throws some people off.What do you mean by "not QUITE as good;" what are some of the more recent problems customers are experiencing?
I can get all those channels with D*. The only reason to even consider TWC is the triple play. However, if I did drop dish TWC would be the easiest to install and setup with them being able to use all the existing wiring. D* would most likely require additional installation of cable, unless they use the single wire method
As for dvr, I am sure that I am spoiled with my 722..
