Programming or Channel Data Rates
gpflepsen
3,301
310
SE NE
Last night I was messing around figuring out the datarates of some of the HD channels off C-Band from 58W to 137W. I was finding quite a variance between some of them, and some of this explained the difference in apparent PQ that can be seen with the naked eye. What started me on this was seeing in close succession the PQ on PBS HD01 from 125W ku and then PBS HD from C-band. I thought the ku feed looked not as good, so i compared some recordings and began making new ones. For example, last night off PBS feeds, the C-Band was somewhere around 14 Mbps and the ku feed was down around 7 Mbps (numbers from my memory). I was going to compile a list for comparison and would jack up the priority if there was interest, or forget it if it's already been done (if so give me a pointer:)). A few sports feeds were up there at ~30 Mbps, expaining why ther usually look so damn good!
Has anyone compiled a spreadsheet with data rates observed for the various channels "up there"?
The picture quality is the reason I participate in this hobby.
Three things matter when it comes to picture quality: resolution, codec, bitrate.
It doesn't matter how high the bitrate is if the resolution is only 720p. It takes some serious bitrate starvation to make 1080i look worse than even a high bitrate 720p feed. This is why News Corporation/Disney owned networks look so awful. ESPN backhauls are easily the worst I have ever seen and they often have a bitrate exceeding 40 Mbps! 40 Mbps is the highest possible bitrate allowed within the specifications for Blu-ray. If you've ever watched a CBS backhaul, you know they tend to be the same bitrate as ESPN - 35+ Mbps, MPEG-2. The key difference? They are 1080i. That is why CBS utterly destroys ESPN and Fox backhauls. Most 18 Mbps 1080i MPEG-2 backhauls I have seen are also significantly better than ESPN's 40+ Mbps backhauls in the picture quality department. All that extra bitrate is wasted when the resolution is only 720p. I've watched 1080i NBC and CBS affiliates over the air and they look better than any ESPN, Fox, or ABC backhaul I have ever seen.
We are also aware of how pathetic quality ABC's fronthaul feeds are, even though they are encoded identical to NBC's fronthaul! ABC is L4.1 H.264 video @ 24 Mbps. NBC is L4.1 H.264 video @ 24 Mbps. They even seem to be using the same Tandberg encoder with the phase-aligned MP2 audio pairs. So why does ABC look so much shittier than NBC? Because NBC is twice the resolution.
The second thing we know is that the codec is also important. H.264 is twice as efficient as MPEG-2 and it's been designed to prevent macroblocking, the worst enemy of the MPEG-2 codec. A H.264 feed can be bitrate starved and still look pretty damn good. It's really only when a H.264 feed is assigned a bitrate lower than 10 Mbps that it starts to look sh!tty.
NBC's backhauls blow most others out of the water. The reason? They tend to be 25-35 Mbps 1080i H.264. You can have a 40+ Mbps 1080i MPEG-2 backhaul and and a 25 Mbps 1080i H.264 NBC backhaul will easily kick its ass.
The last thing is the bitrate. We all know this hobby takes a dump all over the plebs watching over the air, cable, or pizza satellite. OTA and cable both exclusively use MPEG-2 at horrendous bitrates. The bitrate of an over-the-air affiliate can be no higher than 18 Mbps per the ATSC specification; but with the recent subchannel craze OTA affiliates typically vary from 8-14 Mbps. There are not many 18 Mbps affiliates left. Cable is similarly terrible, with most companies now packing 3 to 4 HD channels to a QAM frequency. A QAM256 frequency has the same amount of bandwidth as your typical DVB-S transponder at a high SR and FEC of 3/4 - 38.8 Mbps. If cable companies only put one HD channel on an entire QAM frequency then they could deliver the same quality as the 30+ Mbps backhauls we are used to; instead, they re-encode everything to 9-12 Mbps MPEG-2 to fit four channels to the frequency.
DirecTV and Dish Network are both terrible as they suffer from the same problem as the cable guys. DTV/DN subs don't have motors so the hundreds of channels these companies carry can't be spaced out; they are limited to a couple of satellites only and there simply isn't enough transponder capacity to deliver proper bitrates for HD on pizza. The only redeeming factor of DirecTV and Dish Network is that their equipment does not consist of decade-old hardware so they use H.264. They ruin this advantage however by bitrate starving the H.264 so severely down to ~6 Mbps - half of what the cable companies give MPEG-2 - so Dish/DirecTV don't end up looking any better than the cable companies.
So with that in mind here's some of the bitrates we know of from channels in the clear, ranked in terms of highest quality:
NBC - 1080i; H.264; up to 25 Mbps
CBS - 1080i; MPEG-2 (4:2:2); 36 Mbps
CW - 1080i; MPEG-2; 40 Mbps
PBS - 1080i; H.264; 12 Mbps
NHK World - 1080i; H.264; 12 Mbps
ABC - 720p; H.264; up to 24 Mbps
HispanTV - 1080i; H.264; 9 Mbps
RT America - 1080i; H.264; 9 Mbps
Pentagon Channel - 1080i; H.264; 9 Mbps
NASA - 720p; MPEG-2; 15 Mbps
PlumTV - 1080i; H.264; 6 Mbps
Reelz - 720; H.264; 6 Mbps
This is incorrect. The feeds on AMC 21 are always 12 Mbps 1080i H.264. They look better than the C band feed.
I can agree with this.
Theses numbers seem to align with what I've seen.
My recordings from PBS HD01 on AMC 21 average about 5667 MB for 59 minutes, or about 12.8 Mbps.
Similar recordings from PBS HD on AMC 1 run about 6292 MB for 59 minutes, or about 14.2 Mbps.
Has C band PBS been switched over to H.264 or is it still MPEG-2?
Just wait until there is a fast action scene and you will know, lol! The intro to any episode of "Nature" or "NOVA" I remember being particularly bad... even when PBS was 17 Mbps MPEG-2 on AMC 21, it would still macroblock up when that NOVA swirl came on the screen. Now that they are H.264, I no longer see any blocking on PBS.
Last I heard PBS was ~14 Mbps MPEG-2 on C-Band; so if that is still the case then they are indeed inferior to the 12 Mbps H.264 feed on Ku band. As H.264 is twice as efficient the bitrate of the AMC 21 PBS feeds is equivalent to MPEG-2 at 24 Mbps.
Macroblocking is very apparent on the NBC Sunday Night Football OTA broadcast here during the logo sweep in/out. It is virtually non-existent on the NBC feeds off 103 or 105. I haven't recorded it to know the data rate.
Xizerr thank you for a great informative post!
I've been experimenting with h264 for our broadcasts, we currently use mpeg2 and the difference is outstanding, even at low bit rates.
I've been able to encode video at 7mbps h264 1080i and it looks stunning - this is post processing, not live encoding.
My problem is the same as the big boys - how to persuade customers to switch to shiny new HD boxes!
Worst place to mount a dish
Software needed to edit tp lists in DBS format?
