Love this forum! I got installed this past Thursday and finally had everything set up in-doors perfectly Saturday (installer was a step above brain damaged). My main issue however was that my locals are not HE over satellite, even though the day before I called Dish and they said they would be. My next option was to install an over thew air antenna in time for the Super Bowl today. I got a 3X4 switch for the roof, and two diplexers to split out the OTA in back of each receiver.
My setup is the HD/DVR ViP722 and the HD ViP222, and each serves a second room and a third slave off of the 2nd room. My dishes are the Dish Pro with a single LNB and a Dish Plus dual LNB.
I cut both cables on the roof and added the 3X4 multi-switch. I didn't really know what to do with the line that had the ground, so I left the ground itself dead and added it to the 17V input and the non-ground line to the 13V input. I added the OTA antenna line (antenna to arrive later this week - just getting things set up), and then put the non-grounded coax on output 1 and the grounded output on 2.
Back to the house, and I have conflicts all over the place.
Here's the diagnostic output from the 222:
Sat Input 1:
Port 1 = Sat - 119, trans - OK; Device -Twin
Port 2 = Sat - 110; trans - OK; Device - Twin
Port 3 = Sat - Conn, trans - Small X; Device - Dual
Status = Reception Verified; Switch = DPP Twin w/Separator
Sat Input 2:
Port 1 = Sat - 119, trans - Large Red X; Device -Twin
Port 2 = Sat - 110; trans - Large Red X; Device - Twin
Port 3 = Sat - 61.5, trans - Small X; Device - Dual
Status = Reception Error; Switch = DPP Twin w/Separator
Here's the diagnostic output from the 722:
Sat Input 1:
Port 1 = Conn; trans - small x; Device -Twin
Port 2 = Sat - 119; trans - OK; Device - Twin
Port 3 = Sat - 61.5; trans - Small X; Device - Dual
Sat Input 2:
Port 1 = Sat - 119; trans - OK; Device - Feed
Port 2 = Sat - Conn; trans - Small x; Device - Feed
Status = Reception Verified; Switch = DiSEqC 21 w/Separator
Both TV's have problems pulling signal, especially if both tuners are in use. Any advice that can be provided would be greatly appreciated. Is it as simple as using something other than a 3X4 multi-switch? What about the ground (if that what it actually is) connection?
Thanks!
Janx
Sat Input 1:
Sat Input 2:
Sat Input 1:
Sat Input 2:
Thanks!
Janx
