Problem with second dish on a 625
Zapster
I just replaced my 5000 with a new 625, I did my own install for various reasons, but everything went fine, I got good signal on 119 and 110. Only problem is the 625 does not record the local channels from over the air, so I am adding a second dish.
I have the DishPro Plus LNB with 2 cables running to the receiver. For the local channels I am trying to add a dish to the system. I understand I can just run a cable from the second dish to the 3rd connector on the Dish Pro Plus lnb and that should work, the thing is I can't figure out how to pull up an indication of the signal strength for the second dish so I can point it. I run a check switch and it shows a third port entry but it has a "Conn" where it should have 148 for my local channels. How do I add the 148 to the 3rd port or what is it I am missing? Thanks in advance!!
Will Dish pick up CSTV's new "mtn." regional sports channel?
My 622 Install story
