Problem with sats higher than 83W
madbull
40
tennessee
I just installed a bullseye II feed with four lnbs and it is working great on all sats below 83w. It improved the levels on all sats below 83w. I'm not receiving anything on the sats above 83w, ie 74w, 72w, 61w. I know I must have screwed something up cause I was receiving these sats before the change over on a GEOSATPRO CK1, using the ku band portion only. I'm using a 10ft dish and a ajax h to h positioner, the dish, mount, and feed support didn't change. I'm using a multi switch with power inserters behind it. Anyone have any ideas before I start the trouble shooting process?
I posted this question in the wrong forum before(Mods forgive me). It was in the azbox forum.
Any suggestions appreciated
West of 83 is all good? Does it get worse the further east of 83W you go? Could be the new feed has tightened the beamwidth. I'd recheck the declination, and go through the BUD tune-up procedure from start to finish.
Thanks guys for your thoughts. It has a good signal on all the sats lower than the 83w. just cant get any thing on 74, 72, and61. Will take a look at you suggestions this weekend.
DSR 410 DS
Reed or Hall Sensor ?
