I just had Voom installed today and everything went great except for one minor problem. I have a Samsung DLP (HLN507W) so I was planning on leaving the box on the 720p setting. When cycling through the outputs the only two that are watchable are 480p and 480i and that is obviously not acceptable. When in 1080i mode it is like there are two images layed one on top of the other so it is like I am seeing double. In 720p mode, the upper left hand corner of the screen has the correct image, the upper right hand corner has a repeated portion of the HD image, and the entire bottom third just has a frozen image of whatever was displayed when the output setting was changed. The box still has the 5.08 software so I'm hoping this is just a compatibility problem that will be cured when the box gets 5.68 but I doubt it will be that simple. I know other people here have this TV so maybe some of you guys had the same problem and can lead me in the right direction. Any advice would be greatly appreciated. Thanks in advance.
