Hello everyone
Last year I installed one T90 and one T55 and things worked very well.
Since then I decided to buy another T90 and tyring to align it.
I want to catch sats from 85 to 123. I went to satlex digital calculator and it gives me those infos :
Skey 66.25 and elevation 26.92. I also asked config settings from Wavefrontier and got a different answer.
So I tried those settings and still I can not get a strong lock on satellites at each extremeties. (it was better last year).
So I made sure that the pole is perfectly plumb and tried playing with elevation and skew. I've been able to improve the quality but not enough.
So my question is : When you set the elevation, do you do it with the antenna skew or unskewd (at 90 degrees). Whe do you place the elevation scale ?. When you guys compare your settings to satlex, do they fit.
How could I verify if my dish is warped?
Any help would be appreciated.
Greetings
Labgate
Greetings
Labgate
