I purchased mySolomend PVR800 from Sadoun at Dayton Hamventiontwo years ago. For the last two years I always used the STB as a slave. Ithought I would upgrade the software, and use the STB as a stand alone receiver.So I upgraded the firmware to (version 7/31/11).
I have run into two problems.
1. I noticed thaton the antenna setup screen I lost the field where you can pick if you want toset the vertical or horizontal or both for scanning transponders.
Don’t know if thefield is not supported with the newer release. Without this field it makes it harder toblindscan when using the STB as a slave.
Did I miss thisfield is it on another page or it is gone????
2. As a standaloneSTB I have a problem that the set looks like it is not powering the LNB even with the LNB power field set toon. The signal strength shows 36% and signal quality shows 10% with no LNBconnected. With the LNB connected the signal strength goes up to 43%.
Now I can controlthe motor with both vertical and horizontal transponder without any problem. Sopower is leaving PVR800. But I get no signal. I check the voltages coming outof the cable and they are in spec. It can receive a signal if I use it as aslave, but it does not work as a standalone STB.
Is this a problemwith upgrading the software????
Any ideas on how toresolve these problems is greatly appreciated.
Mike Lib
Mike Lib
