I may try switching it to port 1 for the 105 and see if that helps at all. I also had A LOT of cable. From the dish to my switch alone was about 80 feet. After repointing the dish and getting the best signal I could on 105, I relocated my switc. The installer that came out put the switch where my cable connections were and didn't use water proof connections. I am about 200 yards from the ocean. Our neighborhood requires that a dish go on the back of the house. Our house is 86 feet deep with the cable connections close to the front. I have a home threater with all my electronics 15 feet from the BACK of the house. So, the installer put the switch at the front of the house by the cable connections, ran 80+ feet of cable to the switch, then about 65 feet of cable back to the theater. I just cut the cables he ran and installed my switch inside my house on the back wall of my theater by the electronics. The cables going to the #1 and #2 Receivers on my 942 are now about 18" long each and there's probably 20 feet of cable going to the dish. Now, there's a lot more cable going to the 2 - 811s but they aren't in areas I care as much about except one in my bedroom going to a 42"plasma. The 811s are losing signals now and then. I have a feeling inside this house somewhere they may have some RG59 cable inline. I may have to rerun new RG6. Anyway, what I was getting to is that my 105 jumped up to about 75-78 when I took out a bunch of that cable. I know it's supposed to be able to run 200' but it sure seems to make a big difference the more cable that's there. Oh, and my 110 and 119 are way up over 100. It just seems that everyone is really low on their 105 peaking. I don't know if it's just because there's a much tighter window to tune into or what. I wish I had a meter to use up there with the dish when I'm pointing it. It was literally so sensitive that I'd move it about as much as a gust of wind could move it and it would go from peaking to gone.
So, do any of you installers that read this board know why the Skew would have been off if it was originally installed by a Dish Networks Installer? Isn't the correct way to point the dish to basically set the skew in place right where it says and lock it down. Then set the suggested elevation and azimuth, go back and peak with elevation lock that, then peak with azimuth and lock that? ???
