Fortec CM90 fixed position- Invacom QPH-031 lnbf -S-SM21H 22 KHZ Switch - Mercury II - Signal Booster - 4 X 1 switch with three dishes total. I bought this equipment less then one year ago. Everything is properly grounded.
I have a fixed dish pointing at 129, 123 and 101. When I change channels that would switch to a different satellite. My Mercury II will normally have a very long delay before it will lock on to the signal of the satellite that I just selected. Most of the time it will not switch to the new satellite until I start a power scan and then cancel the scan.
I have replaced and tried 3 different 4X1 switches of two different brands without any help to this problem. This Mercury II shows that it has the current version 1.53 firmware. No modifications have been made to the box or its software, I am not a hacker. No settings have been put into any of the satellites listed in the Mercury II other than the three that I have selected. So I would think that it is not looking for a satellite that I am not aiming a dish at. If I connect to only two of the three satellite dishes then I do not have this problem.
Any information and/or suggestions would be appreciated.
