Hello everyone
I've been installing motors in my backyard for a couple of years and it always worked fine. I have always been able to get from 61 to 129 degrees (trees were blocking everything below 61).
I decided to place a new 16 foot post in the middle of the backyard to be able to get up to T12 at 15 degrees. (I did a site survey first).
I'm using an hh-120 motor.
I'm able to still get everything from 61 to 129, however if I try to get PAS3 at 43 degrees or T12 at 15 degrees, it doesn't work. I have to lower the dish and move a little bit below 61 degrees.
Now for it to work my motor elevation should be at 47 degrees (I'm at 47 lat 71.7 long). However if I want it to work from 61 to 129 I have to put it at 50 degrees.
My motor is really at true south (easy to adjust with amc6).
The thing I don't understand is : if the arc is ok from 61 to 129, how can it be wrong at 43 and 15 (and a big difference).
Honestly I'm not sure where to go from here. I check with a level and the post seems plumbed.
Any idea, or should I give up and be happy with what I have?
Best regards
Labgate
Best regards
Labgate
