Problem hooking a 311 to an 811
mnmbrennan
I recently rented a HD 811 receiver for my living room. I want to hook up a 311 receiver to a television in the basement directly below. The guy from Dish Network said something about having me get a barrel connector and hooking something up to get the television in the basement to work. Can anyone help me out with how to do this?
Could you please give some more info. I know that you will need a coax line coming from the dish for both receivers. You can get in the basement and see how the lines are ran. You can run a wire to the 311 that is in the basement and it will work. Give some more info and I will try to help you out the best I can.
There was a previous system set up with a 522 box in my living room and a coax cable running to the basement to the tv there. There is already a coax cable still there in the basement to hook to that tv. I hope that this helps.
Do you have two Coax cables coming into the house that use to feed the 522? (2 cables go from Satellite dish, inside where 522 use to sit, check to make sure there is 2 cables coming out of Dish, and that at some point inside there is two cables, most installers only run 1 cable through the wall and use diplexers to combine two satellite feeds into one, then one feed back into 2 after getting inside, you should have 3 coax cables in your house, at least by your 811) One cable goes to the 811, the other is not plugged into anything and another cable goes to the basement.
If this is correct, then you can go to wal-mart (or any electronics store) and look for a coax cable barrel, it is about 1/2" long with threads on both ends (actually most are threaded from one end to the other) with a nut in the middle like these http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5823506970&category=50999. You only need one, wal-mart sales them in pairs, so you can have a back up for some other day. (you don't need 100 like this ad is selling, just showed you that so you can get an idea of what I am talking about)
What you will do is take the 1 coax cable that is open from the satellite dish, and screw it onto one end of these, then the other cable that goes to your basement goes on the other end. (it don't matter which one goes on which end, so don't worry about that) Then in the basement, you will take the coax cable and screw it in on the 311 where the satellite feed goes. Then you want to get another piece of coax (or how ever you want to hook your 311 up to your TV) and run it from the output of the 311 to the input of your TV in the basement. You can not run the coax cable to the TV anymore, it has to go to the 311 then to your TV. And that should be that, you should then be able to turn the 311 on and have the ability to use the 311.
Did you have the 811 installed professionally? Did the installer mess with the dish? He shouldn't have, but if you do this and you can't get satellite feed on the 311, check to make sure both of your coax cables are actually attached to the LNBF on the dish. LNBF is the head thingy with the white face that is facing towards the dish on the arm on the satellite dish. The installer could have unplugged it, since he thought you didn't need it anymore. Just hook it up, and if it don't work, check to make sure that is still connected. You can remove the one screw and the LNBF comes off, gently pull it out after removing the screw and make sure 2 cables are attatched, if not, attach the other cable running into your house onto any of the available places on the LNBF. LNBF looks like this http://www.dishstore.net/product_info.php?cPath=40&products_id=229. Also check any splitter looking things between dish and your house, and inside of your house to be sure that everything is still hooked up there, if there was any used.
Good luck,
Hi #1 you need a two way spiter #2 IF ther is'nt two coax wares gonig to the house from your satellite DISH RUN ONE FROM YOU LNB TO YOUR BASEMENT and work from there OK. EL CONDE FROM Puerto Rico
Did Spokane, WA lose their UPN?
Off air HDTV to both TVs using Dish 942
