problem getting ku on my big dish
regulator55
Hello, I have a dsr920 and a 10' dish that I was using with a c band feedhorn and lnb. I bought a new c and ku feedhorn and lnb's but when I go to hook up the ku on the back of the dsr920 receiver my c band channels go out. I changed the setting on the receiver to dual c and ku setup. Any idea what is going on here? Thanks for any help.
I don't know what lnb's you have, but with my set up, I have lnb's and not lnbf's, and the setting is "C-Band and Ku-Band LNBs". Hope this will work. Good luck.
Al
regulator55 said:
...when I go to hook up the ku on the back of the dsr920 receiver my c band channels go out.
Hmm... Do you have separate coaxes for the C and Ku KNBs? If you have a short in the Ku coax, it might be pulling down the LNB source voltage such that it can no longer adequately source either LNB.
Any of you folks visit 4DTV rocks?
HBO DCII signal low?
