I have a older Primestar LNB with one each output, (V) and (H).
I plan to use this LNB with a motor. I understand I should connect the LNB to the motor and then the motor to the receiver.
My question is do I use a DISEqC switch or a multiswitch to combine the two outputs from the LNB to the motor.
Consulting the "Switch setups simplified" area, I think it it calls for a multiswitch in this case and I want to be sure.
