Primestar H V scan question
The Primestar lnbs I have require the 18v to be continuously on the to power the lnb for both polarities.
I have 2
I have 2 P*'s dishes both with the original lnbfs and both are voltage switching and require 14/18 volts or lets say they work using those voltages...
I think I will just upgrade the LNB with one of those Galaxy Marketing that I posted above. Any thoughts?
They will work fine. You might have to take the plastic off the LNB right behind the eye to fit it properly in the groove. I used a Sadoun dual on my P* dish
Can a multiswitch run through a diseqc switch?
I tried another Primestar LNB that I have, and got the same thing: only duplicate V and no H. It is hard to imagine that H is bad on both LNBFs.
I have H and V running into the multiswitch (which I tested in post #17) then the multiswitch runs into diseqc port 4.
On the Coolsat I have LNB Power On; Single; 10750; 22khz off; diseqc 1.0; committed 4
PC to STB comm via serial cable
Need Help with I pro 2000 plus
