Starting a new thread for the top secret stealth dish I retrieved on Saturday. I'm saying it's top secret because a search of the Internet found exactly... nothing.
What you have here is your world famous Precision Parabolics 12 foot mesh dish made in that hot bed of communications technology, Nanaimo, BC. I somehow doubt they made over 10,000 of these but it looks like they must have produced at least somewhere around 400 based on the serial number. (Picture 1)
Here's a look at the mounting mechanism from the rear. Notice the rust where the sleeve slides over the post. We were unable to spin the sleeve to remove the mounting hardware intact from the pipe. No identifiable manufacturer marks on the actuator. (Picture 2)
Front view of the dish showing the 4 feed arms and Chapparal LNB. Shows bolts through front plate attaching ribs to centre of dish. (Picture 3)
Rear view of the dish on the ground. Some of the arms, nuts, bolts etc. are rusty and need to be cleaned up or replaced. The two white bushings are pretty dried out. Shows nuts on back plate attaching ribs to centre of dish. (Picture 4)
We attempted to save the pole. We were able to jack it far enough to confirm the pipe was set into some concrete for approximately the lower 3 feet of the pole. Figured that even if we were able to lever the pole out we would not be able to lift it onto the trailer. Cut off above the concrete then dropped the remains back into the hole for reburial. (Picture 5)
This view shows how the mesh slides into channels and how the ribs are attached around the circumference. (Picture 6)
We saved around 2 metres of pipe which won't be enough to remount this dish. But, living in Alberta I'm not worried about scrounging a chunk of 3 inch steel pipe.
From the pictures I have posted can anyone confirm whether this is a unique design, or a clone of another dish using a similar manufacturing method?
Since I have a long list of projects to complete this summer, and some of the hardware will need to be cleaned up or replaced, I think I am going to break down all the panels for storage so mesh doesn't get damaged, poles bent, etc.
Comments and suggestions are appreciated, thanks in advance.
