I am set to have Dish installed next Friday and have a few questions. I am currently a Voomer so I don't know much about the Dish installation process. I wish this forum had a pre-install FAQ like the Voom forum does since I am sure all of my questions would be answered by it.
Here is what I am getting: 942 with America's Everything Pack + locals + HD pack. The 942 will be installed in my living room with a coax run to the non-HD tv upstairs in the bedroom.
What kind of satellite signal should I receive for each of the various satellites that I need to pick up? I know my Voom dish only has to see one satellite and I have a 97% signal reception. Also, what satellites will I be pulling channels off of? My zip code is 47150, Louisville KY area.
I already have an OTA antenna mounted that is currently hooked up to each of the coax runs with a diplexer and then split out at each Voom STB with another diplexer. Since I will now have two coax runs going to my living room, how do I handle the OTA antenna. Will it be combined with a diplexer into one of the coax lines, or will they want to run a separate coax for it?
I am counting a minimum of three coax runs that will need to be made for the 942, two from the satellite to the 942 and one from the 942 to the upstairs bedroom. Does the standard Dish install package limit the number of coax runs and total cable length? I want to leave my existing Voom system alone since I plan on watching it until it goes dark. Who knows, maybe a miracle will happen and it won't go dark
Thanks!
Thanks!
