PowerVu question
PowerVU encryption is only (so far as I know) on commercial receivers.
You might find one surplus, but from previous threads, you won't be able to get it authorized.
....Unless you are a cable company with thousands of users, and willing to pay for thousands of subscriptions.
Also, there is no centralized clearing house - you do business directly with the uplinker (owner of the copyright).
I'm no expert on the subject, but I hated to see no better answer to your post. :)
Anole pretty much nailed it
If there is more than one channel in the mux that is Powervu the uplinker can turn on one station, 2 or all depending on the parameters the cable/satco needs
The only PowerVu stations that are non-commercial technically is AFN (Armed Forces Network)
If you are in the military you can get a receiver that decodes it (D9234 last I checked) and subscribe through the military
POwerVu receivers will work on FTA channels but usually there is a setting you have to change to make it work with FTA
I think there are different levels of encryption,maybe powervu or powervu plus.
Some channels have the video encrypted powervu but audio in the clear.
To the OP: Powervu is just a scrambling system. Depends on which satellite you were seeing the channels on, but there are many, with different uplinkers providing the channels. To answer more directly: There is no service in the US that makes any of those channels available to us, as end-users, unfortunately. They're cable-channels and only the cable companies could get authorized for reception/redistribution. Too bad, too, we could get a ton of tv if anybody would sell direct to fta'ers. >Sometimes they turn that encryption off, and you might get to watch one of those channels for a while!
I just picked up an Scientific Atlantic PowerVu D9835 today , from a local resale shop , for $4.99 . Found a manual online , a few minutes before I read this . Hope it wasn't a total waste of money .
its a real basic receiver. Did you get the remote with it?
Reason I ask is there is a hidden menu that requires the remote (or a universal that works with it)
If you need a remote, I may have one. I just have to dust off the retired component area of the basement to check.....
Thanks for the offer & help . Yeh , it came with a remote . Played with it last night , haven't got anywhere yet . Both fta lines into my house are on 4x1 disqec switches , I only see a 22 kHz setting , so will have to run 1 lnb to it , for set up purposes . I don't fully understand the net ID number . Did find the "PowerVu" setting in "advance settings" and switched it fta viewing . So figuring the net id , just might be for commercial use ?
Classical music for Huntington Beach Feeds
Please help me to identify this LNB
