PowerDVD
lacubs
1,596
42
Erie, Pa
about 2 ago, i notice when i play a BLU-RAY disc, on some scenes are mess up, but when i put PS3 the disc play find, any idea? can that be a java issue ?
We are going to need a bit more information.
What player are you trying to use where it is messed up? Does the player have an internet connection? Is it messing up on all discs, or just some newer ones?
Reason I ask is that the BluRay standard is slowly evolving, and players often need updates downloaded in order to play some newer content. Of you don't have an internet connection on the player, try hooking one up and letting the update download and see if that fixes the problem.
If that isn't the problem, we are going to need more info: Make and model of player, cables you are using to connect, make and model of TV, is there a receiver in the signal path, is is all discs having issues, etc.
We are going to need a bit more information. What player are you trying to use where it is messed up? Does the player have an internet connection? Is it messing up on all discs, or just some newer ones? Reason I ask is that the BluRay standard is slowly evolving, and players often need updates downloaded in order to play some newer content. Of you don't have an internet connection on the player, try hooking one up and letting the update download and see if that fixes the problem. If that isn't the problem, we are going to need more info: Make and model of player, cables you are using to connect, make and model of TV, is there a receiver in the signal path, is is all discs having issues, etc.
this on my pc, the discs play find in my PS3, i try to update the powerDVD but it came with the pc, so it won't let me update it without me buying a newer version, and when the discs mess up it's only mess up for 10-15, then it go back to normal
thanks , that what i was afraid of, does Blu discs play in Windows Media Center? or Blu Ray only play with PowerDVD? and thanks for information
i never thought of anydvd, but that will work, but i have one more question does that mean your have buy a newer version of PowerDVD every year because of copy protection?
thanks for all the information,but unfortunately they stop update mine version, no big deal, but again thanks for your guys help
Pandora Sees Quarterly Revenue Grow 55 Percent
How automakers shield your car's electronics from hackers
